Need help grinding a Becker BK2 from the spine.
I'd like to bring the edge of my BK2 all the way down from the spine, getting rid of the factory edge, but have never done anything like that to a blade before. What is the best way to go about this?
I would like to grind it from the flat, down to the edge, getting rid of the secondary bevel, so that it is completely flat ground.
I would hesitate to go to a full zero flat grind. I think you may find that you have some durability problems on the edge!
Take it down to .010" and then put a slight secondary bevel on it and I think you will be happy.
If you want a true zero edge I would recommend a zero ground convex edge or a scandi grind.
Just my .02
Tom
I looked into what you said, and I believe that scandi grind accurately describes what i would like to do. My knife terminology is sadly lacking.
I looked into what you said, and I believe that scandi grind accurately describes what i would like to do. My knife terminology is sadly lacking. Thank you.
i have some pictures that will help show you how to put a scandi edge on or if you want to put a convex edge on you can do that too. if its a new knife and you want to go with the convex edge, i would slowly work it down to a convex edge so you dont take life out of the knife edge. over time a convex edge will form.
