I trying figure out where from and who made it seems to be a ceremonial sword i think.
Awesome advice i was just thinking of the blue pads.You need a solvent to soften the crusty rust and then bronze wool or something softer than steel. There is a good article and discussion here. http://www.swordforum.com/forums/showthread.php?78325-Sword-Care-amp-Conservation
I use a lot of different tools and materials in my own little shop of horrors. Something I have used with good results is Noxon. This liquid polish has oxalic acid, which helps loosen rust (aluminum oxide as the abrasive-shake well). Slather it on, let it set in wrapped paper towels, then an abrasive like a copper Chore Boy or blue scrubby pad. Those are found in most grocery stores. I have tried out a number of household and automotive solutions aside from the standard weapons items. Aluminum foil with oil or even water (I'm not much impressed but it works). Plastic wood and even metal picks.
Nevr-Dull, a great product. White spirits, cotton wadding, silica and clay.. Bon Ami cleansing powder, another favorite and very minimally abrasive. The blue scrubbies are very low abrasive.
Liquid-Wrench, on the harsher side but does bust rust (ventilate, wear gloves). Also on the more aggressive side (but messy) is 0000 steel wire wool and light oil). Picreator products include a de-corroder that needs tending while working it and like liquid-Wrench, will leave a gray tone that will need polishing.
Noxon and Simi-Chrome are on the milder side of abrasive polishes with Nevr-Dull
Some use yet harsher acids (nitric, etc) and even electrolysis. On the lighter side, even baking soda has a bit of abrasive property. I have used it in a slurry with water. So, so many options up to and including tooth paste (for that minty fresh taste). I do have an electric toothbrush I use for nooks and crannies but a regular one works as well. Plain old kerosene and #2/deisel are decent penetrants.
In the end, not exactly rocket science. We are just working with whatever materials we are dealing with. Dixie Gun Works has grips and butt/pommel parts for a cavalry type and may work out for this one. Looks like the tang would have to be extended to original length.
Good luck
GC
