So I have used my SFA enough over the past few months that I wanted to tune the edge back up on my 800-1000-6000 grit King waterstones and then strop it a little. I have never done this before and honestly was a little intimidated but need to do it. I watched Ray and a few others on youtube and it seems as though the masses seemed to agree that doing a circular stroke up close to the business end is the way to go because of the inconsistency of the angle it encourages a slight convex shape so there was no issue there. Well let me back up because there was an issue straight from the factory because the cutting line jogged over almost 1/8 of an inch from top to bottom if I looked down on it from above so I had to remove a fair amount of metal to true and straighten the line but not a huge deal. Where I am having trouble is whether I should try and do the Ray Mears slicing technique like you would typically do with a knife or do many of you just continue the circular motions all the way down to the tip. I tried both and obviously need more practice because it is definitely sharper and will kind of slice paper and will cut paracord with ease but shaving sharp...not really. Right now I can go either way/style but want to see what you prefer and why. Furthermore are there any tricks to maintaing consistent angle? I don't think I did a very good job and was honestly surprised at the results and thought maybe the the subtle variations in angle are less important on an axe. Thanks in advance.
