Need help please!
I just ground out my first template out of 1080 steel. All I have is an angle grinder , what would be the best way to put a hollow grind on the blade using the angle grinder or should i use something else?
You're not going to be able to do a hollow grind with an angle grinder, only a flat grind. You would need a belt grinder with a wheel to do a hollow grind. I'd suggest a flat grind for a first knife anyway. If all you have is an angle grinder you might even want to try files for your first try. If you want to use a grinder and don't want to spend the money on a full size 2 x 72, I'd suggest looking into a 1 x 42 Delta or Harbor Freight.
Im sorry but your not gonna do any good with an angle grinder, not with a hollow grind or any kind of finish grind..The angle grinder will work for removing large ammounts of material or cutting out blanks but Id strongly suggest using files and sandpaper to finish the knife with..May I humbly suggest you consider a flat grind for now..Easily made by draw filing with a good file..The block and sandpaper..More work but you will be much happier in the end..
don't dismiss the hollow grind too quick
careful stock removal with an angle grinder and a few carefully made scrapers and you could manage it.
a flat grind would be MUCH easier for a first knife though
I have to agree with the others.
Flat grind is much more reasonable to do with hand tools
Have a look at the filing jig under hand tools, you can also do that with your disc grinder, but it's setup for flat grinds too.
I've put this together to answer most of a new maker’s questions. I'm sure it will help you too.
The Standard Reply to New Knifemakers V21
The answer to a 13 year old student is different than to a 40 year old engineer.
We may recommend a local supplier, you may have a helpful neighbour, or local Hammerin; but that depends on where you are. We have members worldwide.
Please fill out your profile with your location (Country, State, City), age, education, employment, hobbies.
Look at the threads stickied at the top; many are expired, but not all.
The basic process in the simplest terms
Absolute Cheapskate Way to Start Making Knives-Printable PDF-Right Click and Save
Absolute Cheapskate Way to Start Making Knives-Website
Web Tutorials
Detailed instructions by Stacy E. Apelt
The Things I Advise New Knife Makers Against-Printable PDF
Handle Tutorial - Nick Wheeler-PDF
http://www.engnath.com/manframe.htm
Books
A list of books and videos
BladeForums - E-books or Google books
I like:
David Boye-Step by Step Knifemaking
Tim McCreight-Custom Knifemaking: 10 Projects from a Master Craftsman
These are clear, well organized, widely available and inexpensive too.
Knife Design:
Think thin. A paring knife slices, an axe splits.
Forget swords, Saw-tooth spines, guthooks, crazy grinds and folders for your first knife.
Start with a drawing.
Show it to us, we love to see and comment on photos.
Then make a cardboard cutout template & draw in handles, pins and such
Then make it in wood, paint sticks are free & close to the right size.
Play with that and see if it “feels right”. If it feels right it usually “looks right“
See the Google books thread for Lloyd Harding drawings, the Loveless book & Bob Engnath Patterns. Google books thread
Bob Engnath Patterns compiled into a PDF
Forging Books:
Lorelei Sims-The Backyard Blacksmith
An excellent modern book with colour photos for forging in general - no knifemaking.
Jim Hrisoulas- has 3 books on forging knives. Check for the cheaper paperback editions.
The Complete Bladesmith: Forging Your Way to Perfection
The Pattern-Welded Blade: Artistry in Iron
The Master Bladesmith: Advanced Studies in Steel
Machine Shop Basics -Books:
Elementary Machine Shop Practice-Printable PDF
The Complete Practical Machinist-Printable -1885-PDF
Right Click and save link as.
It’s being reprinted now; you can get it for $20 ish
The $50 knife Shop
It confused me for a long time.
Forging is NOT necessary; you can just file and grind to create a knife (stock removal)
Forget the Goop Quench.
Use commercial quench oil & match oil speed to the steel type; even grocery store canola oil works much better.
Junkyard steels require skill and experience to identify the steel and heat treat it properly.
You can buy proper steel like 1084FG from Aldo very cheaply.
I like cable damascus, but that advanced project has no place in a beginner’s book.
The grinders are the best thing about this book, but there is a huge amount of info for 2x72” belt grinders on the web, including free plans.
Forget about Lawnmower blades and start with a new known steel type.
Good heat treating needs accurate temperature control and full quench.
Videos
Heat Treating Basics Video-downloadable
Right click and save this. Watch it once a day for 10 days.
Safety-video
Many specific how to knifemaking videos are available, some are better than others.
The best overall Knifemaking video I have seen is
“Steve Johnson-Making a Sub-Hilt Fighter”
Basic Bladesmithing
"Ed Caffrey - Basic Bladesmithing-Full DVD-ISO"
The best video on leather sheath making for beginners that I have seen is
“Custom Knife Sheaths -Chuck Burrows - Wild Rose”
-(Paul Long has 2 videos, his sheath work & videos are fantastic, but more advanced-with machine stitchers..)
Green Pete's Free Video
Making a Mora bushcraft knife, stock removal, hand tools, neo tribal / unplugged heat treat.
"Green Pete" posted it free using torrent files.
Be sure to look at the other titles too-The account index has disappeared, but search for LOTS of info. Use the keywords “LurkerLurker torrent” “knifemakerC torrent” and others
Greenpete Knifemaking Basics-on TPB
How to download that video
http://www.utorrent.com/help/guides/beginners-guide
You can see a list of videos and reviews at this rental company; some are worth buying, some renting…
http://smartflix.com/store/category/9/Knifemaking
Draw Filing Demonstration
YouTube video -Draw Filing-for a flat finish
Steel
The “welding steel” at Home Depot / Lowes… is useless for knives.
Forget about lawnmower blades and other unknown junkyard steels.
For all the work involved, it is very cheap to buy and use a known good steel.
If you send out for heat treating, you can use
Oil quenched O1, A2,
Or air quenched CM154, ATS34, CPM154, 440C, plus many others.
For heat treating yourself with minimal equipment, find some Eutectoid steel.
1084FG sold by Aldo Bruno is formulated for Knifemaking, Cheapest & made for DIY heat-treat.
http://njsteelbaron.com/
Phone # 862-203-8160
1095 is a good carbon steel, but a bad choice for a beginner with limited equipment.
1095 needs very precise temperature control and proper fast quench oil Like Parks 50 or Houghton K Kevin Cashen - 1095 - hypereutectoid steel
If you are sending one or 2 knives out for heat treatment, use 154-CM or CPM-154 and ship it out to TKS -Texas Knifemaker Supply
It's the cheapest way to do 1 or 2 because of HT minimum charges.
You can find a list of suppliers here
Heat Treating
http://www.bladeforums.com/forums/showpost.php?p=9143684&postcount=7
You can send blades out for heat treating at $10 or $15 per blade for perfect results, and avoid buying the equipment.
Air Hardening Stainless Steel Only
Buck Pau Bos -Be sure to check the Shipping and Price tabs.
http://www.buckknives.com/index.cfm?event=bio.paulBos#
http://www.texasknife.com/vcom/privacy.php#services
Oil Hardening Carbon Steels and Air Hardening Stainless Steel
http://www.petersheattreat.com/cutlery.html
http://www.knifemaker.ca/ (Canadian)
Glue – Epoxy
Use a Fresh package, slow setting, high strength epoxy to attach blades to handles and well as seal out moisture.
Surface Prep is vital, drill tang holes/ grind a hollow, roughen the surfaces with abrasive, blasting is best.
Ensure the surface is clean & no oil including fingerprints. Soap, Acetone & Alcohol, Blasting.
Clamp with moderate pressure= avoid a “glue starved joint” when all the adhesive is squeezed out.
These are well proven.
Brownell's Acraglas
West Systems G Flex
Grinder / Tools
In my opinion, variable speed and a small wheel attachment are essential .
You can almost always improve tracking with more belt tension. It needs to be way tighter than youfirst think.
Hand Tools
You can do it all by hand with files and abrasive cloth like the Green Pete video.
Photo of a nice bevel filing jig
Entry Level Grinders
Many makers start with the Sears Craftsman 2x42 belt grinder
Low Speed Modification Craftsman 2x42 belt grinder
Commercial Production 2 x 72” Belt Grinder Reviews
http://www.prometheanknives.com/shop-techniques-3/grinders
http://www.cnccookbook.com/CCKnifeMakingGrinders.htm
Mapp arm – Grinder Toolrest
DIY 2 x 72” Belt Grinders
KMG Clone Free Plans
http://www.dfoggknives.com/PDF/GrinderPlans.pdf
NWG No Weld Grinder
http://www.usaknifemaker.com/plans-for-the-no-weld-grinder-sander-nearly-50-pages-p-723.html
EERF Grinder (EERF =“Free” backwards)
http://wilmontgrinders.com/EERFGrinder.aspx
http://blindhogg.com/blueprints.html
Buy the kit
http://polarbearforge.com/grinder_kit.html
What Belts to buy?
http://www.usaknifemaker.com/abrasive-belt-basics-what-kind-should-i-buy-p-1393.html
Safety Equipment
Protect your -Eyes, Ears, Fingers, and Lungs – remove jewellery and put on safety gear.
Respirators
Chronic lung disease and cancer really suck the joy out of life.
The minimum I would consider are the 3M 7500 and North 7700 silicone half masks with a P100 Filter.
Use a VOC & P100 combo cartridge for protection against acetone and solvents.
For beards, pick one of these
3M PAPR
Resp-O-Rator
3m Breathe Easy
Trend Airshield Pro
Air Cap II
Searching
Search works for ALL users, even unpaid users.
Try it, I’ll bet you’re not the first to ask the question here
This is a special Google page that searches BF only.
http://www.google.com/cse/home?cx=011197018607028182644:qfobr3dlcra
V21 Added Glue Oct 3, 2011.
