- Oct 18, 2001
Yes, I know this is an old argument and Yes, I have read the archives on this subject. My problem is, though, that having read all that info has made me even more indecisive that I was before!
Here's what I'm looking at:
I do mostly flat & convex grinding on a newly acquired KMG-PL.
Here's the setup I am imagining so far:
Before Heat Treat:
Rough grind with 3M 967 at 36, then 60 grit.
Then ______ at 120 - 220 grit.
After Heat Treat:
Clean up with ________ at _______ grit
Final edge grinding with Norton 150 - 400 grit belts.
Hand sanding with ______ paper at 600 - 1200 grit.
Sharpening with either 3M Micron or Trizact belts.
How's that look? Can anybody help me fill in the blanks? Am I missing anything (or in the wrong order)?
I've been doing everything on a 1x42 and so this will be a great improvement no matter what it is. Just need to make the right decision on the belts.
Thanks!
Dan
Before Heat Treat:
After Heat Treat:
Thanks!
Dan
