- Dec 12, 2006
I decided to finally try sharpening my 0560 with my KME sharpener, and after suing the Sharpie method I think I finally figured what the factory edge was. Problem is I've been sharpening with my coarsest stone for what seems like forever and there are still two spots on the blade where the very edge of the bevel has sharpie on it. I'm not sure if I should just keep hitting those spots until all the marker is gone and then going for the burr or if I did something wrong.
If I rest the stone on top of the blade and put my angle cube on top of the arm the angle comes to about 23.7 degrees which I thought was pretty steep for a factory edge unless I'm not doing it right. It's set to here on the KME itself:
Is what I did with the angle cube the proper way to get the true angle and is my KME that far off with its system?
Here is what the knife looks like, you can see one of the spots in the main focus area. There's another spot heading toward the tip of the blade.
Thanks for any tips. Hopefully I didn't mess this knife up yet.
