I hear $100 bills work on most strippersI used citristrip on my DS6. But now the INFI is dull. How do I shine it up?
Thanks!
lets see a pic of the stripper. I usually start with 180 grit and finish with about 400 grit. Then I move to scotch brite pads to try to give it a uniform look. It also depends how marked up the steel is. Some blades are very clean under the coating, others have huge marks, Something like that may take a rougher grit start. Be careful if you use a belt sander with fine grits. They do not take much off and they create a LOT of heat. INFI is a very wear resistant steel so it takes a lot of elbow grease to get it done.
Scotchbrite pad on benchgrinder...Scotchbrite brush on Dremel in tight spaces.
Keep the pad away from the edge, of course.
Keep the blade moving and attack from different directions to be thorough and to help blend the swirl marks the tool will leave.
Only then do I use sandpaper, and sometimes it isn't needed then.
On my bombproof HG55, I had to use a few specialty tools because of all the unique nooks & crannies of that model <shown below>-- but on most models. Just the scotchbrite has gotten me as far as I need to go.
Next, some good ol Mother's chrome polish and elbow grease buffing it out.
If I feel the need, I add some Ren. wax and buff it till I can comb my hair in the reflection of the INFI.
If you don't remove all that decarb, the INFI will still look dingy and may attract some surface rust...even then it's no big deal.
Once you get down to platinum INFI, you have essentially the easiest to maintain, tough, tool steel that's for all intents and purposes stainless. Great stuff...exactly why INFI is my all time favorite!
a couple other strippers I've turned out using those steps:
You got a lot of work ahead of you, lol. The blade itself does not look to bad, just the ricasso.
Didn't you read what I said? The ricasso hasn't been stripped yet.![]()
lol, it looked stripped haha
Nope, I let it go on both sides. Plus I was worried about the citristrip messing up the res c.....will it or is it harmless over a few hours?
Thanks
I used citristrip on a B11, no change to the Res CGood question. I am sure someone here has done this. I have never stripped a basic so I would not know. I would like to know though, cuz I may strip my basic 9
Thanks for the info and pics.
I'm not sure of the technical names but I have those wire wheels and stone cone for my dremmel. If I can avoid the hours/days of wearing out my arms, is it possible to just use those or is the sandpaper a requirement?
In either case, what dremmel bit do I use first and does speed and pressure matter?
Thanks!
