OK, i'm apparently too stupid to figure this one out on my own and the manfacturer of otherwise awesome and really high-class binoculars couldn't be bothered to explain it in the manual either, which only proves i'm really slow
This is my predicament:
I got new binoculars as a gift. They came with two objective "cups" (you know, the shieldy-thingies that you put on to protect objective lenses from scratching and all, shown in the right hand side of the picture below). I'm not exactly sure how to put these on. This is what i've tried so far:
1: i put the rubber ring (bottom right corner in the picture) on so that it was aligned exactly with the end of each objective "tube"; when i did that the cup thingy (show in the picture in top right corner) couldn't be put on at all because the rubber ring stretched around the objective and became of same diameter as the cup itself. The cups would never strech far enough to fit over those rubber rings so that's obviously not how it was meant to be.
2: then i figured those rings must be moved further down the objective "tubes" (towards the left in the picture below). When i put them further back the cup could finally cover the objective but it was totally loose, meaning that if binoculars were dangling on the strap around my neck as i was hiking both cups would fall off the objective "tubes" immediately and wouldn't protect them anymore. Obviously this isn't how it's supposed to work either :grumpy:
3: i also attempted a "compromise" and put the rings approximately halfway between position from 1st and 2nd attempt - this way didn't work either.
One thing i haven't tried yet is to move the rings even further back so that the cups would hang on on their own (pulled from the side by the ring).
The diameter of those rings when they are not stretched fits exactly into the cups (inner diameter of the cups matches outer diameter of the rings).However, objective tube stretches the ring.
Any suggestions ? I feel really dumb asking about something that must be painfully obvious, it's just that my poor brain cannot figure it out by itself
Any helpful pointers would be greatly appreciated !!!
