Plumber, Thanks . Great pictures . Those are mfg. 1981-86 and have 425M steel .
If they have two micarta spacers in the pommel they are 1981 mfg. and could be either 440C or 425M . DM
Great info DM, you guys never cease to amaze me with the info you have, either in notes or top of head.
BTW, knice nives Plum....new to your collection?
Thanks for the info David. There's just one spacer in the pommels so they are '82 to '85? If they had a second spacer in the pommels would they also have a spacer on the handle side of the guard? I have a NIB 105 that has four spacers.
From what I understand not all 1972 are stamped upside down, but if you get one stamped upside down then you know that it is a 1972.
Plumber, According to the handouts from Joe H. seminar at the 20 yr. reunion on the 100 series your 105 fits exactly into Group 2 1973-80 (440C blade). Then BG, your correct, according to the same sheet a up right stamp is 1973 . Plumber on your #10 post your first sentence is correct 1982-85 (some bleed overs)(425 steel) . Your second question is, yes for (1973-80). If is has two micarta spacers in the pommel it will have two micarta spacers in the finger guard of Group 2 . However, the 1981 knives do NOT do this . One micarta spacer in the guard and two in the pommel Group 3 (440C or 425 steel). Hope this clears up somethings as this is confusing . DM
Plumb it should be between 1972/1980 with a 440C blade. In 1981 they went to one micarta spacer at the gaurd, then to one at the pomel.
