- Jan 19, 2013
Hi knife bros!
I found an old axe and I bought a new handle for it. I didn't check the measurements beforehand and I wanted to return it but the other ones are the same size and that size is "too small"
I can fix the side gaps with a wedge but there's a gap in the front.
Is this handle usable? I was thinking about making a wedge that is thicker in the front to fill the gap and the part that goes into the handle would be normal, ie narrower. I would glue the wedge in and fill any gaps with epoxy. I would also put round metal safety wedges.
The other solution is to put a metal bar in the back of the axe head and bend the metal outwards so it fills the gap and it can't move when wedged in.
Any other suggestions?
I wish they didn't narrow down the handle in the factory because now I can leave it like that and risk the poor fit or take out a lot of material to try to fit it properly.
BTW, the gap on the dies is 5 mm/0.2" and in the front 10mm/0.4"
One more thing, I almost forgot. Is the axe head upsidedown?
I think the flatter side should go up but my grandpa said this is the correct orientation.
