- Feb 1, 2016
So I picked this Knifeart.com exclusive Sebenza 21 large up used. It has the Carbon fiber scale with a ladder Damascus blade. Since day one it has been driving me nuts. The blade is not centered at all, and not just the tip. The whole blade is off center as you can see in the pictures below.
[/URL][/IMG]
[/URL][/IMG]
Now, I understand that not all Sebenzas have a centered blade. However, in most cases I've seen its just the tip of the blade off center and not the actual body of the blade. As you can see in my knife the whole blade is favoring the CF scale.
Now I've read that pinched washers can cause all sorts of problems. I however am new to CRKs and have no idea what a pinched washer looks like. So I took photos of both sides of my washers to see if anybody here could tell if they were pinched or not.
[/URL][/IMG]
[/URL][/IMG]
Here is a picture of wear marks on the Titanium lock side. To me it looks like the smaller washer is wearing unevenly. Then again I'm not 100% sure.
[/URL][/IMG]
Now, on the blade stop sleeve one side has a raised lip while the other side does not. I believe this is only on the Carbon fiber models. Not sure though. My question is does the raised lip go towards the CF side? Or towards the Titanium side?
[/URL][/IMG]
The last thing I'm having trouble with is the Pivot/tightness/smoothness. When I tighten the pivot screw down it makes opening the knife almost impossible. So I have to back off the pivot screw ever so slightly to be able to open the knife. I should state that I am NOT wrenching down on the pivot at all. Just enough to feel tension then I stop.
I also should mention that I am using CRK grease. Please help guys it's enough to drive a guy mad. Should I send it in? Would CRK do anything about it? Is there a home remedie I could do? Thanks in advance for the help!
