Need Help With Stone Celt
I have been looking for just the right materials for my next Celt and would like to avoid some of the mistakes I have made in the past so this one will last a bit longer. I'm going to harvest a few small trees to make bow staves out of and I like to do these types of projects with as many Paleo-accurate tools as possible. Most of the groups in the Mid-Atlantic used a small Celt instead of a stone axe for shaping wood. We know that because of the shapes of the blades and stone heads that are found in the Delmarva area. The Celt that I want to make will be short, about 12 inches total, which is a bit smaller than most I've seen but that's the size that works best for me for working bow staves.
My previous mistakes:
Using the wrong stone- I used some of my heat treated Ft. Payne chert. The heating makes it much better for cutting but also a little more brittle and less suitable for an impact tool.
Not wrapping the haft- I assumed that since the Celt doesn't fully penetrate the handle that it would not split- I was wrong.
Wrong adhesive- I used some left over Hide glue that I had made for attaching a sinue backing to a stave. I just got lazy and didn't want to melt the pitch down like I should have.
THIS TIME
I'm using a piece of Blue flint, raw not heated.
Coal burning the haft opening instead of scoring and cutting- will help reduce splitting.
Wrapping above and below the stone with some sinew that I processed last week.
Using pine pitch instead of hide glue for the setting of the stone.
My question:
I know that the sinew fibers stick to themselves when wet and shrink when dry. How tight can I wrap them before the shrinkage breaks the protein bond that binds them when wet? I use sinue strips to set arrow heads and knife blades but have never used them on a haft this thick and want to avoid mistakes.
Hey Md 25v,
I can't help you with your question, but are you sure that coal burning the opening will reduce splitting?
Doc
It will be more smooth than cutting with a stone knife. I don't use steel tools for these projects or it wouldn't be a problem. A good crooked knife would carve the shape smoothly enough that I could sand it and there wouldn't be a mess of loose, disturbed wood grain. Unfortunately the stone blade I'm using for this is made or heated Noviculite. It cuts very well but can't be made thin enough to cut cleanly as deep as I need to set the head.
Not sure if I explained that well...
Neat work you're doing! :cool: Got any pics?
What about carving most of the shaft, then using coals to smooth the torn fibers? Seems like it would be a bit easier.
I think you should be able to wrap the sinew fairly tight before it dries...it's tough stuff. Plus, you don't know exactly how much it will shrink...it may not be much, and you don't want the lashing to be loose even after it dries, or you'll have to start over. :grumpy:
Good luck!
Frosty
I know it will shrink about 10% in length. My concern isn't with how strong the sinew fibers are, thats definitely not a problem. Sinew that is wet sticks to itself because wetting the sinew allows the proteins that are still on the fibers to bond to each other. The sinew threads I have left are only around 7 inches long so that's only gonna get 1.5 turns per thread around the handle. As the sinew shrinks (around 10% in length) it will be pulling on the protein "glue" that holds the already separated fibers together. The sinew itself will not tear, as you said it really strong, but the fibers that I have already processed and separated may come apart.
I'll post pics over the weekend when I finish. Then I'll do a tutorial of the whole bow making process using only Lithic tools.
Sinew that is wet sticks to itself because wetting the sinew allows the proteins that are still on the fibers to bond to each other...it will be pulling on the protein "glue" that holds the already separated fibers together. The sinew itself will not tear, as you said it really strong, but the fibers that I have already processed and separated may come apart.
Ahhhh, ok. I was picturing knots. :o
I can't wait to see pics of the process!
Good move with the pitch.:thumbup:
As for the sinew, I find with the amount of force for such a tool, even the best sinew will begin to loosen or open up over time in terms of adhesion.
I would recommend scoring above and below the haft into the wood to lay a track for the sinew, this will help in the long run IMO as you can do a few laps this way to thicken it if you want, which will retain more adhesive glue. I use plenty of hide glue and spackle over once more, as the sinew is now somewhat countersunk. This should hold fine.
If you want, you can add a layer of pitch prior and then the sinew. That way it won't shrink to the point of losing adhesion plus imbedding it in the pitch somewhat. This actually looks very nice IMO. I do this with bamboo at the cracking nodes. You can even spackle a line of pitch over the sinew to protect it.
The thickness of the sinew is another thing to consider.
Pitch and hide glue are really your friends here!:D
I'm sure you'll do a great job! I can't wait to see it myself!
Thanks PaleoJoe, the recess for the wrap is just the thing I need to keep it from rising up the shaft. I'm also switching from Maple to Hornbeam for the handle so that should also make a significant difference to the durability.
I tried something earlier this week and I think it will help protect the wrap. I took squirrel intestine from one of the ones I hung for jerky. I split it, cleaned it, and hung it on the rack with the squirrels to dry. When I took it off I soaked it for about 30 seconds in hot water and it became pliable. I wrapped a small stick to test it and it did not shrink or self-adhere. Then I coated it in hide glue and twined it like cordage. I wrapped the stick again and this time it held strong. I think this has potential to be a protective wrap over the sinew. I think a little more experimenting is in order.
Nice! Squirrel gut cordage!
Another method I have seen is wet-molding rawhide with glue like a jacket and stitching it where it meets along the shaft. Dries tight. Pretty darn sturdy, maybe a little overkill for your purposes...
Nah, I'm pretty clumsy. If it can be broken, I'll find a way. I think there is a correlation between how many hours I put into a project and how likely it is to break. The last bow I made took about 15 hours hands on plus the drying time. As soon as I finished tillering both sides I bent the arms and they were fine. I sealed the wood and strung it up, knocked and arrow, pulled it back about half way to test the flexion and start working in the arms and SNAP. Man that sucked!
