Congratulations. Now your axe has some patina.
But the black spots are under the area where the rust used to be. It is not like the whole axe head is color in black
Patina is found under rust , so yes patina is exactly what that is.👍
Since you are working with a head that can't be removed from the handle, I wouldn't just soak the head - vinegar might discolor the handle as well.
You are looking for a uniform color on your axe head? When people talk about using vinegar and axe heads they are usually using it to remove rust and junk.
Doing this will leave it a grey color that probably won't look how you want. Sounds like you are trying to force a patina or go for a more aged/uniform look.
Your axe head will rust after soaking unless you oil it or something.
Do those Gerbers have a coating of some sort on them?
Since you have already started it seems... Here is something to try:
1. Strip all the coating off of the head and dry it.
2. Get a piece of cord or string and run it through that hole in the handle (so you can hang it up).
3. Take some Dijon (thick) mustard put a tsp. in something the size of a mayonnaise jar lid.
4. Add a little white vinegar to it and mix to a light paste.
5. Cut a new sponge into strips.
6. Dab your sponge into the vinegar mix and apply a light/even/uniform coat to the head.
7. Hang it up to dry - use a hair dryer even
8. Do this several times.
9. Rinse and repeat.
This will start rust on the head which will become forced patina.
When you are satisfied, scrub it in the sink/with a hose, let it dry, and oil it. WD-40 works or whatever you have.
It stinks, takes a long time, and all steels act a little different.
It's a gerber. I have an old one and it doesn't have any patina and has been put to bed wet, left outside, and it doesn't look much different that when I got it - mine has some coating on it.
From my experience it isn't from just soaking once and letting it sit. I think it has something to do with the drying process more than the amount of time it sits in the vinegar or the amount of vinegar so maybe it's the number of times it's applied.
This process "stinks". Oh, and maybe use mustard without seeds lol.
A picture would be fun.
*Remember to refrigerate after opening.![]()
Not sure a Gerber / fiskars axe is a good candidate for a vinegar soak , but I'm curious to see how it's gonna look so post some pictures 👍
