You can always grind distal taper ....this one is from 5mm thick steel .Weight of blank is only 125 grams after grinding , it was 280 grams before grindingI’ve recently had special requests for 3/16 or thicker hunters.. kinda crazy to me but a couple just cleaned out some deer with them and said they were perfect. Personal opinions of what works for them I guess.
If you have it and want to use it then go ahead and make a full tang or a couple of small edc blades.
Had to look twice to realize this was tapered back to front AND top to bottom. That’s nifty.You can always grind distal taper ....this one is from 5mm thick steel .Weight of blank is only 125 grams after grinding , it was 280 grams before grinding
Thanks ! That's happens when you chasing perfect plunge line . . . . . This one is second one I make this way .On this one I grind ONLY one sideHad to look twice to realize this was tapered back to front AND top to bottom. That’s nifty.
Very nice! Wow hahaYou can always grind distal taper ....this one is from 5mm thick steel .Weight of blank is only 125 grams after grinding , it was 280 grams before grinding
I use 3/16 for all my knives pretty much i just finished up some field knives for a few customers they are 3/16 x 1.3 x 9.25
Sounds like the dimentions of a good user knife.
4" hidden tang 5" blade
The one with the mustard is A2 the other one is AEB-LAny chance you could post a picture of one of yours?
