The Sanyo batteries are a viable option. You may be able to get nearly the same thing cheaper at Radio Shack. Their cat# 23-525 NiMH battery is rated at 1500 mAh (may be higher; they keep raising the rating as the battery technology gets better; this same battery was 1300 mAh a couple of years ago).
While it is true that NiMH batteries have a slower discharge under load rate than NiCds, a higher self discharge rate and a lower maximum charge rate as well, these properties do not cause real world problems.
I use four of these RS batteries in my Casio QV-3000EX digital camera. Have taken up to fifty pics with plenty of charge left. The flash recharges quickly. It is hard to imagine a higher drain item than a digicam, with a powered telephoto lens, powering the flash capacitor repeatedly and running the hard drive.
I have a charger which has a switch for two different charge rates, a lower charge current for NiMH batteries. However, this is not really necessary, since the maximum charge rate of the charger (set to the higher NiCd rate) is still below the maximum charge rate of the NiMH batteries. Thus, it is only a 'feel good' switch. The higher self discharge rate is not a problem. My digicam batteries stay good for a month easily, as do my cell phone batteries.
Certainly a PDA draws nearly no current in comparison. My Palm III runs for months on two AAA alk cells.
Hope this helps, Walt
