- Nov 9, 2019
I’ve been using a 1x30 belt sander an edge pro and whetstones for quite a while now. I rarely use the edge pro anymore. Mostly whetstones on the kitchen knives and the belt sander on everything else. Unless mobile sharpening then it’s all on the sander.
I’m wanting something but can’t seem to find exactly what I’m looking for. What I want is either a slow speed or a variable speed 1x30 or 1x42 belt sander that can be adjusted to lean back. Variable speed or slow speed is not 100% necessary but I’d prefer it. I also want it to also have a grinding wheel or buffing wheel on the other side.
I want to be able to have a sanding belt on one side then make a leather strop/buffing wheel for the other. I do a small mobile knife sharpening gig on the side. I don’t make much off it but it’s more of a hobby.
My plan is to have my current 1x30 belt sander set up with say a lower grit say 600. Then the new one set up with 1000-1200 grit and the leather wheel. Just seems like it would expedite things instead of having to flip flop belts all the time. I don’t really like “batch” sharpening where you run all your knives on one belt then the next. I like to work on one knife at a time. When setting up at a flea market ect I often get one or two knives from a customer not 10.
If I wind up getting a 1x42 I’m going to replace the 1x30 with a 1x42 that I have and set it aside as a back up. That way I’d be running the same belt length on both machines.
Anyway any suggestions? On a side note I know they are more expensive but I’m also considering a 2x42. My only hold back is I’m noticing they have a more limited grit range. However I have read that you can run 1x42 belts on them just fine.
Anyway any guidance would be much appreciated!!! Thanks.
