RokJok said:Jeff Higgins posted a picture of his funnel arm (leading to a shop vac) that he installed below his grinder (attached picture). I though it was a very ingenious idea and stuck it in my archive of shop setups and tips.
Note that he didn't run the vac while grinding, to avoid sucking hot sparks into the vac. The funnel caught the debris and held it until he was done grinding, at which time he would turn on the vac and suck up the metal dust that had accumulated in the arm.
blgoode said:Well....I am tired of living in DUST!! Any ideas to mount a mouth under my grinder so I can hook a dust collector to it?
Thanks in Advance![]()
DAMNENG said:Just remember to put a spark arrestor between you vacuum or dust collector system.
blgoode said:Can you describe this portion? Thanks for helping my little brain stiff up ideas![]()
DAMNENG said:My spark arrestor consist of a 20mm ammo can which I epoxied two pvc fittings to the cover. One fitting in the corner nearest to me when I grind, goes to the collection hose (vacuum cleaner hose)/scoop under the contact wheel, the other fitting is a female 4" pvc which I insert a four foot section of pvc pipe. This pipe runs straight up and connects to the flex duct that runs to my dust collection system. Inside the ammo box I have surrounded both the intake and exhaust ports with two layers of 1/4 inch mechanics cloth. Just cut the cloth so it is slightly compressed when the ammo can lid is installed. This will hold it in place. To clean out the ammo can, pull the 4 foot pvc pipe out of the output port and set it aside, and unclamp the lid and set it aside. Then lift out the mechanics cloth tubes and you can take the entire ammo can outside and wash it out with the hose. Most of the dust from handle materials is light enough to pass through but the metal and grinding grit settle to the bottom.
If you need some pictures I can email them, don't think I have photo posting
rights.
My dust collection system is the PENNSTATE portable, which I hang from a section of unistrut secured to the ceeling. The dust bag just hangs down from the unit.
Hope this make sense to you.
Jim Arbuckle
rights.
Jim Arbuckle
