Need some advice on how to get a good finish on vintage micarta?
Hey everybody. I could use some advice on how to best finish vintage micarta handles. This is my first time working with micarta in general and can’t seem to get a good finish. This was some clearance vintage micarta from Pops and I know there will be some variation but don’t know what to expect. I keep removing material, but I can’t seem to address several areas and most specifically the dark area towards the but end of the knife. All advice is appreciated. PXL_20221113_143708680.jpgPXL_20221113_143721221.jpg
If you want a shinier uniform color, you need to sand it to 600-800 grit and then buff it. If you wipe it with WD-40 or similar, it will look how you want temporarily, but then fade out again. You really need to buff it.
Thank you. Do you use any buffing compound when buffing?
I sand to 600 and buff with brown tripoli compound.
The dark spot on the butt, is residual from the micarta sheet's top layer which always is darker. Sand away and buff again, if you want it gone.
Another trick to get rid of those "white-ish" looking fibers is to, after final sanding, flood the micarta handle with Teak Oil. Let it set for a bit, then thoroughly wipe off the excess. Then, after it dries well, you can buff if you think it is necessary. Gives a nice warm look to that old vintage stuff.
That's awesome - thank you!
As pointed out by Robert, a lot of the unfinished look after sanding Micarta is the fibers that make up the material. Canvas and burlap are the worst.
What makes the dull or whitish look is the frayed ends of the phenolic impregnated material the Micarta was made from. The trick is to sand it smooth to a fine grit and then "fill" the frayed fiber ends with something.
Many folks us a coating of baby oil, but most folks don't like an oiled knife handle (and it wears off). I am not a fan of this method.
The better method is to use a drying oil like Tung, teak, walnut, Watco, or any good quality dried oil type wood/gun finish.
Sand to 400-800, buff and clean the handle well. Then apply the finish (Teak oil or similar) and let it soak into the frayed fibers, wipe it off before it dried fully, and let it cure fully before a final super-fine sanding with 1000 grit and buffing.
As Bill pointed out, a final coat of buffed on hard wax, like Brix or carnauba, will make the handle look wonderful. However, it usually isn't necessary if you buff right.
Tip - The color coated 3-M sanding cloth-like papers are perfect for handle finishing and work really well on Micarta. A pack has 400 grit through 8000 grit.
There is absolutely no need for oils or waxes. Just sand to 600 and buff.
