Sando
Knife Maker
- Jul 4, 2002
Heading to MN for our family reunion, which always involves filleting a ton of bass. This year instead of a narrow, thin western fillet knife, I want to try a wide, thick Japanese deba.
The more research I do on debas, the more puzzling it becomes. These heavy beasts are usually 7mm/0.275" thick at the handle and then distal taper to some unknown thickness just back from the tip. And they are single beveled without any or much of an edge bevel. So ....
If the blade is 0.250" thick and the bevel is 0.75" wide, then the edge angle at the base is 19.5 degrees. That sounds reasonable, as that part of the blade is for chopping bones.
If the blade distal tapers to .050 and the bevel is a consistent 0.75" wide, then the edge angle is ~4 degrees. That's way too thin for an edge!
So does this sound correct (I've never actually used a deba, so I don't know)?
- 0.250" thick, tapering to 0.130" with a 0.75" wide bevel. That way the edge is ~20 degrees at the base and ~10 degrees at the tip.
Question 2:
- Would it be a sin to make it a double bevel?
I can't seem to get the hang of using a single bevel knife. Of course, the bevel would be half as wide to keep the same edge geometry.
Question 2:
