Those are all great tips, but the folding knife kits aren't really that complicated. All the parts are machined and heat treated. Its really about the same amount of work a as a fixed blade, only theirs a few more peices involved. Al you have to do is, put on the handle material and put it together. The locking mechanism is completely done, just not assembled. The only thing you may feel like doing other than shaping the handle and polishing up the liners so it works smoothly, is to hand finish the blade a little better. At least with the kits I got, there was a small amount of pitting in the back of the blades from heat treat. And they hadn't been taken to a very high finish with the regrind. All in all its pretty simple, just a little more time consuming than a fixed blade kit.
Oh yeah, one thing you will need is a shim for when you peen the pins. There are two things you can do. The first is to find somehting thats only a couple thousands of an inch thicker than the tang of the blade and put it in between the sides of the handle to keep it from pulling together to tight. The second thing to do, and the easier of the two, is to go spend the $2 or $3 ona tune up tool(aka feeler gauge) Its just a set of small slabs of steel precision ground to certain thicknesses that fold into a handle. Each slab is marked with a different thickness. You will probably want to use the .005" peice. Slip it in between the tang and the liner on one side of the knife. Then peen the pin, and pull the tune up tool back out. That way you have about .005" of extra space around the blade to let it work easily without play.
Fix it right the first time, use Baling Wire !
