- Dec 18, 2001
I have just come into possession of an original Leatherman Supertool manufactured in September of 1996. I'm wondering what I should do with it, but first let give you fellow forumites a brief rundown of it's condition.
The handles are virtually pristine, with an original shine and only a very slight scratch here and there. All of the blades and tools inside are in good condition as well, with the sole exception of the narrow slotted screwdriver, which shows distinct burn marks and evidence of twisting. Apart from that, and a speck or two of crud on the saw, everything is intact and functioning normally. The piece butterflies more easily on one side than the other, though the handles are by no means loose. The needlenose pliers, on the other hand, are a different story. They're completey blackened, as though exposed to open flame, and the jaws are ever so slightly off alignment ~ probably the result of applying more torque than the tool was designed for. The wire cutter has been sorely abused, causing indentations in the metal which, when I first closed it, caused the jaws to stick shut for a few moments. A little WD-40 solved that problem and now they open and shut just fine but still with a hint of stickiness at the close. I've checked very carefully and the jaws are not loose nor coming apart or showing signs of failure. The very edge of the handle on one side, right on the end of the metal nearest the pliers, is slightly dented as if someone had hammered something with it. Overall the tool is still very serviceable, but as I see it I have a few choices. I can:
A) Use a Dremel to carfully grind off the bent metal on the wire cutters, thus rendering them useless but allowing the pliers to close and reopen smoothly.
or
B) I can live with it as is.
or
C) I can send it to the factory and ask if they can replace or repair the pliers.
So....advice anyone? It's so frustrating having everything in good working order except those unsightly pliers with their jaws blackened and sticking slightly. Should I try sending it back to the factory to ask for a replacement of the needlenose pliers? Or should I grind the wire cutters and call it a day? Or should I just leave it as it is?
or
or
