Need tips on bending annealed steel
Phil705
Basic Member
I cut out the profile of two hidden tang knives. I cut the handle to have a slight curve, but I'm considering an antler handle. Is it advisable or possible to bend the handle (1/8th steel, about 1/2 inches "thick") to better fit the curve in the antler? It has not been heat treated. How? Tips appreciated.
Cold bend it. Heat is not necessary for this, and depending on the steel, it may air harden, making drilling a pin hole difficult if you wanted a cross pin.
Thanks for the replies. I'll try to cold bend it, and if that doesn't work, I'll ensure my holes are drilled and try heat.
