- Jul 8, 2014
So, I got this 3.5 lb Kelly Perfect and it was one of the most bashed up heads I’ve ever worked on. After hours of wire cupping and filing, I decided it could be salvaged. I had a straight, octagonal, 36” House Handle that I wanted to use. I got it nicely fitted, shaped a wedge to fit the tricky eye, tapped it into place then drove it home. For the first (and last) time, I set the base of the handle on a thick piece of quartz I had left over from a Reno. When the wedge was set and I put the axe in the vice to trim the wedge, I noticed a chunk of the knob had broken off. I trimmed the knob to remove the chipped section. My question is this: is there enough swell to use this axe safely? Can it be used, or would you cut off the handle and hang it again?
