- May 24, 2019
i currently have the work sharp precision adjust and am considering a higher end wicked edge or tsprof.
aside from the flex in the WS, my biggest complaint is every time i need to resharpen my most used knife, i have to reprofile the edge with the 400/600 grit instead of just rehoning with the 800 grit. i do have the little spacers that set the angle indicators to the same angle, and the block that goes under the knife holder to help with the flex, so in theory the angle should be the same every time, but it's not.
is this the case with the WE and tsprof? just set it to the angle you need and it will line up every time? or will i still need to reprofile with a courser grit before i move to a finer grit?
