Nessie and her nest ;-)
Thought I'd make myself a nessie for my trio. A nice thin slicer/skinner, 1095 carbon,with a vinegar etch and hamon.:D white tail handle. The sheath is dyed Elk over 9oz veggie, painted fringe in the plains style, with brass studs.
Sorry for the really crappy pics.
Best regards
Robin
[/url][/IMG]
[/url][/IMG]
Beautiful! How is the tang secured?
The tang is long, wide and curves to past the half length of the handle, notched all around the edge of the tang then filled with steel epoxy and dust from drilling out the stag. The ferule is leather soaked in crazy glue. I usually pin the tang but have made lots like this one and they have never come apart with real hard use.
Best regards
Robin
I usually do not like the look of antler handled knives. That is a beautiful knife for sure! Combined with that sheath and it puts it well over the top. Excellent work, sir!
Hey Shooter
I just scored a Huge pile of antler with so many good handles.:D I like to build Nesmuks with a dropped handle, it alines the curved blade tip up well for skinning IMO. Thanks for the comments, much appreciated.
Thanks Mike, how is the burl coming along?
Best regards
Robin
Thanks Robin. I have a custom chopper and plan to mount it in an elk antler tine. Was wondering about molten pewter to fill around the tang versus some sort of epoxy as you noted.
Hi Pullrich
Using molten pewter might be a problem as it would likely cool and harden before you got the blade in the hole and all centered up. If you're thinking a design on the outside of the handle in pewter you could set the blade in good epoxy and do the pewter fancy work after. Doing it that way you would have to watch that the molten pewter didn't heat the handle to a point of softening the epoxy. On a big chopper I would put a pin or two through the handle and tang as well as you're likely going to be putting it to hard use.
Best regards
Robin
Good points, I should probably work with epoxy. Any recs for brands?
Considering a pewter bolster, maybe even something like a subhilt. The tang will be fitting all the way through the antler and is threaded at the end to receive a bolt. So cap and bolt at bottom of hilt.
Any good 1 hour epoxy should be fine, i use lepages. The threaded tang should work great. I'll be interested in seeing how it turns out, you do very nice work.
Best regards
Robin
Great looking knife and sheath to boot. I always enjoy seeing what you will come up with next. I like the primitive style. Regards. Lee
Thanks Lee
The winter gives me time to play and make new stock and some toys for myself (usually sell them anyway))). I'm making a companion piece for this knife and sheath, a small belt pouch as a "strike a light" kit. I'll post it in this thread. Right now I'm doing a rawhide sheath for a member here to cover his frontier hawk.
Best regards
Robin
Thanks Ed and Dusty for your comments.
R
