Hi Ulfberh,
I saw your comment earlier this month on my post in the “Models, Tang Types, Steel Thicknesses, & Weights” thread where I discussed my preference for a neutrally balanced knife if possible. My collection has changed a lot since that post and I am working on a new thread with updates in the near future.
Since each Fiddleback is handmade and unique, there are slight to significant variations even in the same model that effect balance. Steel thicknesses, tang types, handle materials, grind height, and final handle shape all contribute to this equation. This means that there are no “standard” models or individual features that guarantee what you are looking for.
For example, here are two Bushfingers that were made less than a month apart earlier this year. The top one is 1/8” O1 with a tapered tang and the bottom one is 5/32” O1 SFT with a thicker handle. These are not going to balance the same.
I use the first set of pins as my reference point for determining neutral balance on many models.
Most 3” and 4” models will balance somewhere between the first and second sets of pins.
Here is a Patch with 1/8” SFT that shows a balance point typical of most 3” models that I have tried.
Here is a Bushcrafter (thicker handle) with 1/8” O1 SFT that shows a balance point typical of many 4” models that I have tried.
My experience with the 5” models is that they have the best chance of being neutrally balanced, especially with a tapered tang.
Here is the best balanced knife that I own, a Big Sneaky with 5/32” O1 & tapered tang.
I’ll have more detail later when I finish the draft of my larger collection analysis.
In the meantime, look for the following features to increase your changes of getting the neutral balance that you desire:
1) Tapered tangs definitely help to move the balance forward. In my experience the forward change ranges from 1/8” to 3/8” depending on steel thickness.
2) Look for models where the blade portion is longer and/or taller than the handle with a 2/3 to 3/4 height grind. This combination with have enough metal out front to offset the weight of the handle.
Here is a Camp Nessie with 5/32” tapered tang to show what I am talking about.
I hope that some of this helps you with the search for your perfect Fiddleback. Good luck.
Phil
