 - Oct 3, 1998
MOD's new Elishewitz Phoenix is an interesting conecpt in fixed blades.  A fixed blade in which the blade can be extended more for bigger cutting jobs, and retract for the smaller ones.  PResenting the MOD Phoenix, designed by Allen Elishewitz
Closed, its blade length is 2" Opened, it is 3 1/2" in length. 154CM steel blade, OAL is 7.1", and the molded sheath is of a composite material called Prilon.
The blade slides in and out of the handle, though never fully retracts inside the handle, on what MOD calls its Bear-Trac system. There are actually small "wheels" fixed in the blade tang that ride on tracks inside the handle. The result? Very smooth action. To extend the blade, press the locking buttn and tilt the blade down towards the floor. Blade slides out and release button to lock in the fully extended mode. To retract, do the opposite.
The Phoenix's blade is coated with tungsten DLC for the ultimate in corrosion resistence.
SRP is $169.98 and is available in both plain and part serrated versions.
