Can't help you, my only BaTac is at the custom shop for the indefinite future, but I can show a pic.
AZTimT, I noticed you bobbed the pommel, was it a nuisance? anybody else?
What did you use to cut it/grind it?
I am the odd duck in a crowd...
For big straight cuts a flooring tile saw works great with it's water cooled blade to cut through rock & steel easily without any noticeable heat. Then sand the rest by hand or low speed dremel sanding drum. A guy could also use a dremel cutting disc at lower speed for a similar type of result, just keep dipping the knife in the water every few seconds to keep it cool. It is much easier to do than to describe as it sounds more complicated than it really is. Many make a big deal of heat treat issues, but if you can touch it with your bare hand, you aren't hurting anything.
