New bulat blades
nozh2002
BANNED
New bulat blades from Ivan Kirpichev:
Thanks, Vassili.
What I like about Ivan - that he always experimenting, in his search to perfection. I am looking forward to compare this blades with his first blades I already have.
Thanks, Vassili.
As well as I know he for several years making bulat and he come to the point when he fill comfortable to give his bulat blades away. He send it to me and as I know to some other people to have a look. But I don't know so far does he making it for "commerce" or not. I know he send few blades to US. May be this people will speak up. All what I have I published already.
Thanks, Vassili.
What is the hardness? How does the performance compare to various common cutlery alloys?
-Cliff
-Cliff
So far I did 2 tests which does not wokr as I thought - wrong methodic.
1. I whittle oak:
I hope at some point it just stop cutting - I was wrong I finished my testing after 30cm because of permanent pain in my wrist.
And it continue to cut and continue to cut newspaper.
2. I cut rope
To awiod damage of my arm I made this "equipment". Again after 320 cuts (12 feet) it continue to cut and I have no rope.
So I consider this as not bad, but I like to make better job with testing.
Now I came up with thread cutting to really measure sharpness after thius tests and I sharpening set of knives to compare and measuring sharpness.
http://playground.sun.com/~vasya/Testing-Res.html
And as for hardness - it is exactely as in antient time - nodody know.
When I finish my testing I'll send it to you - remember - we have some conversation over mail few monthes ago, but things happend too slow. However it will be possible to test old and new bulat from Ivan - I'll make handle for this blade over weekend.
Thanks, Vassili.
As I promised - I made handle over weekend - I need few days to polish handle with finest sandpaper, and then I'll start testing.
And on this stage of production you may see betteer handle geometry:
That is a very fine looking handle. I would prefer the front to be a little less flared as I often grip around the choil area, but that looks very nice for hammer and similar style grips.
-Cliff
-Cliff
After I cut my pointing finger badly by SOG Navy Seal 2000 I am kind of paranoic in terms of secure grip. For example - this is my stake knives set
as you may see they have good guard :) just in case who knows what may happen when you get overexcited testing good thick stake!
However for gentle kind of work I do make angle on the front of guard - it has diamond shape if you look from the top (picture #4) and it is possible to hold it with 3 fingers around this "diamond". IMHO it is even more comfortable this way because fingers grip it better then flat handle.
Thanks, Vassili.
Yeah, it depends on the knife, how it is being used. Some of my EDC knives have little to no guard like :
http://www.physics.mun.ca/~sstamp/images/aj_utility.jpg
or
http://www.physics.mun.ca/~sstamp/images/parrell_parang_side.jpg
lack if a guard does limit some use such as hard thrusting, and forces a certain perspective on use.
The grips on the steak knives are really striking.
-Cliff
OK, I finally made it:
After, I sharpened it it shows good result
Knife №78 (Bulat second run by Ivan) - 57+/-12.36
Better then befoer
Knife №73 Bulat first run by Ivan - 78+/-20.74
Busse Model T Street (INFI) - 60.67+/-11.12
Benchmade Nivramus (High Speed Steel - M2) - 56.67+/-9.94
Knife №71 (Lauri UHB17Va Progressive Tempered) - 63.67+/-9.28
Buck Vangard Alaskan Guide (CPM S30V (Paul Bos)) - 57+/-8.77
In general with this mathod and thid deviation I may say they are all same sharp.
I may try to resharp first run - may be I did something wrong with sharpening, because it was first in my testing when I was not quite skilled yet (same for Busse).
Thanks, Vassili.
I have never seen any significant difference in sharpness either unless you go to really low angles, ~5 degrees or so, as then you may see breakouts on the coarse grained steels.
-Cliff
-Cliff
In theory you may expect from bulat internal carbides structures to affect edge sharpness, because this inpurityes are harder then steel matrix. However it is in theory and may be too microscopic to effect sharpness noticible.
Achim Wirtz sad something about it (about stainless bulat):
"sharpness of the edge is not as good as in classic wootz because the same chromium carbides are a lot bigger than iron carbides and the carbide size determines the minimum size for the edge. But that's not as important because this heterogenous steel is made for draw cutting anyway. If you want a perfect blade for push cutting and it has to be made from steel, nothing beats a plain carbon steel. If it can be from non-steel, take an obsidian edge."
http://playground.sun.com/~vasya/Bulat-Achim-Stainless.html#English
Thanks, Vassili.
Boye's knives have a huge network of segregated carbides and this isn't a factor for them. They can still take a hair popping edge. As you noted the carbides are simply too small to be a factor. You can actually see the aggregates in wootz though, but sharpening them didn't seem to be a problem for you.
You can take a plain carbon steel and give it an aggressive edge with a rough stone and the teeth will be many times larger and readily outslice steels which have inherent aggression due to hetrogenity. I did this readily with Boye's dendretic steels. It is fairly trivial to test, just cut some 3/8" hemp on a scale and measure the force required on a two inch draw.
-Cliff
