- Nov 3, 2000
Got my xmas present set up, 2x6x72 grinder (3 step pulley) with a 1 1/2 hp motor(4 step pulley). Started on my firt practice blade...what a flop. Ended up warped (? too much heat), plunge line all messed up, grind lines not even. So, I cut the blade off and tried using the handle for a neck knife. A little better attempt, but still the same, tip heated up, grind lines and plunge lines a bit better, but still ugly.
On my first knife, hand filing the master blade bevel took time, but my lines were kept fairly even. I am half tempted to grind the outline of the blade and finish it with a file
Opps sustained: knuckle touched moving belt (1/4" deep abrasion), neck knife got away from me (went between the grinding platform and the belt, then slammed to the ground, ripped my new belt
Loveless makes it look so easy in his book "How to make knives".
I can tell, it is going to take practice. How many knives did it take before you got good at symmetry in grind lines and plunge cuts?
