New Critters - with Tutorial
Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
I have a box of silver plate flatware at the store from a batch of sterling I purchased. The silver was mainly scrapped, but what can you do with old silver plate?
I made up about 20 critters from the spoons and forks. Some are very simple, and others complex. I will post a group shot soon. They range from snails to dragonflies.
Here are a few.
The squid is made from two spoons, and a soup spoon as the base. All the tentacles are cut from the spoon stems with a 5/0 saw blade. The grasshopper is in sterling from a Gorham silver spoon and some cocktail fork handles.
The spider is a sterling spoon and two forks.
Also, I found this shot of a quick bolting of my tractor shed door during the hurricane.
What else would a knife maker use to bolt a door shut?
Love those bugs stacy, my neighbor gave this chime to me, made from oneida it hung for awhile before i realized that cat eating the fish theme! Cool stuff i might try my hand at makin some bugs that would surely get my boys in the shop more with me!! Every now again ill do some belt buckles, heres some early ones made w/ n/s, resins, etc. My last buckle i inlaid a piece of rattle snake skin in, one of our members has that one. Cool post, reminds that there is more than knives to make, in the shop!! Thanks. Greg
Here are some group shots. My favorites are the squid, mosquito, and the "Feeding Frenzy" wind chime. notice that the striker is a jellyfish cut from an ice tea spoon. My wife likes the wind chime.
More shots of the critters
Awesome. Ever think about doing a Zodiac theme? You already have some of the signs handled (Cancer, Pisces). Throw in a scorpion and a few naked people, a bull and a goat... voila! :)
Maybe I should post pictures of some of the other things I make (pillow covers made of leather and fabric, for example).
Scorpio is already there. Post#5 photo, #4 top right critter; and post #6 ,photo #1, top right critter.
The crabs are made from two spoons and two forks.
Those are beautiful, Stacy... I need to learn how to solder...
Here is a little copper pendant I made my wife for our anniversary...
and some other rough looking jewelery... yours makes these look like cheap fishing lures...
I have been making some non-sea life critters, and thought you guys might like a tutorial on how to do a simple spoon critter.
This is for a mouse/squirrel, but a small amount of shaping difference and it becomes a beaver, a platypus, a skunk, etc.
Please meet the famous spy fighting duo, "Mouse and Squirrel"...or was that Moose and squirrel????
First - the spoon. Use a nickle silver or silver plate spoon ( unless you want to use sterling). Stainless won't work.
For these small critters, I use teaspoons. Use a thin ( thickness) spoon, as you will have to do some bending. Baby spoons, jelly/sugar/olive servers, and other thin spoons work great.
Mark the cut lines with a Sharpie, and change anything that is not looking right. You are basically drawing the shape of a road kill squirrel.
Make the face and body parts fatter than you think looks right until you get it down pat...you can always cut/file some off if it is too fat. You will bend the edges down to give some shaping to these areas, and they will end up thinner.
Tools - use a jewelers saw and a 4/0 blade. You will break a lot of them, but heavier blades won't turn for the curved cuts and reverses. TIPS - Go slow, use even strokes, take your time, hold the spoon firmly in contact with the cutting arm, lubricate the blade with some candle wax. Most important is DON'T saw Up and Down...saw down only. A jewelers saw has the teeth pointed toward the handle, and cuts on the down stroke. You will ruin the blade in seconds by sawing back and forth. Cut down with a nice even and smooth stroke.Then slightly back the blade off while lifting the saw back up for another down-cut.
You will also need two small jewelers needle nosed pliers with smooth jaws. A round nose or chain nose pliers is also nice to have.
Take a 6" piece of 3/8X1/2 maple and band saw a slot 3" down the center of the 1/2 side. Drill a hole on the unslotted end and screw it onto your work bench so that it sticks out. Use this to do your cutting on, with the saw blade riding in the slot, and the spoon on top of the board.
Procedure -
Make cuts from both sides going from front to back. Cut the teeth, then do on side of the face, then the other. Next, do one front leg, then the other. Do one back leg....the other. Cut out the"belly fat" between the legs, leaving the side flap. Cut the tail as desired - fat for a squirrel, thin for a mouse. You can see in the photos the shape drawn out, and then the pieces cut off. Notice that most of the body parts nest into each other and only the excess spoon is cut away.
Once all the cuts have been made, file any rough places or points with a fine barrette needle file.
Lift the legs up a bit with the pliers, and bend the side flaps down and under the belly. This creates a 3-D effect of the squirrel having sides. Turn the front and back corners of the flap inward more than the sides to round it a bit.
Next, move the legs down a bit, and bend the ears up into position. Twist as needed to look right. Grab the cheeks with the pliers and bend the edges down to shape the face. If you have a punch, mark the eyes and nose.
Now, bend the front legs down and turn inward to get a realistic look. Do the back legs the same. Bend the elbows of the front legs to make the arms position right, and bend the wrists to make the hands have some movement. Do the back legs as needed. Bend the tail up and curl it as needed to make the animal you want. For a mouse, file the tail into a round taper, for a squirrel, make it flat and widen toward the end.
Once all the parts have been bent, position the legs/feet so the animal sits right. Keep adjusting things until you like the pose.
Lastly, bend the teeth down as needed to be a rodent. I took a piece of the cut off spoon and made a piece of cheese. I placed it in the mouse's hands and used a tiny bit of soft solder to hold it in place.
Give the critter a light sanding with paper or a cratex wheel to remove any tool marks, and then buff with a brass or nickle wire wheel to make a matte finish.
That's it...no magic, just some simple hand skills and a good eye for what looks realistic. Looking at some photos on the computer while drawing and shaping your critter will help a lot.
The horseshoe crabs are cut the same way from a ladle and a spoon for the claws and gills.
Here are some more shots...sorry they are pretty crappy, but you should get the idea. The Geico Gecko just sort of took shape in my hands as I was forging a face from a fork handle. It is just two forks. I like how I was able to capture the speaking lips. He looks a lot better than the photos show.
