New Dark Khopesh Blood Sword of the Nile & Featured Tactical Leaf Blade
Archer Here
We have just released our newest blade to our site.
Dark Khopesh Blood Sword of the Nile – Just Released
This is a darkened blade bloodwood version of our original Khopesh Sword of the Nile. Full tang heat treated blade is designed for usage under extreme conditions and is virtually indestructible.
Flash through video of our original Khopesh Sword of the Nile. Demonstrations on wood and logs. Watch it chop a log in half in one swing.
Shop Details:
1095 High Carbon Spring Steel. Steel is Heat Hardened & quenched. Heat Tempered @ 500 degrees for 2 hours, and letting it air cool.
Measurements:
Total Length = 25 ½ “
Blade Length = 17 “
Blade Width = 1 5/8 “
Blade Thickness = 3/16 “
Handle Length = 8 ½ “
Handle Width = 1 3/8 “
Handle: Bloodwood & Steel
Weight = 2.8 lbs
ONE OF OUR FEATURED BLADES OF THE WEEK - Tactical Leaf Blade:
Fully functional tactical version of the ancient and effective cut and thrust Leaf blade shortsword. Leaf blade shaped swords are one of the earliest types of blade - first made in bronze and then later iron. Used as a backup weapon by the ancient Greeks, Spartans and Celts. The classic design is perfectly balanced between cutting, thrusting and hacking.
Professional reviewer Jason Woodard completed extreme durability tests from Slicing Multiple Jugs, to Chopping a Tree, Stabbing into a Metal Trash Can, Striking against a Metal Pole, Chopping on Hard 4x4 Pressure Treated Wood as well as Solid Composite Deck, Striking against a 55 Gallon Steel Drum, Chopping CONCRETE, and then Striking against SOLID GRANITE.
