- Feb 13, 2009
see this link
http://www.toolsfromjapan.com/store/index.php?main_page=index&cPath=335_462_463
"sintered diamond plates" from 150 to 12K !!!!!!!!
i'm broke, who wants to buy a full set for the team ?
it's just about 800 dollars ...
These plates differ in that the diamonds are sintered to the steel substrate by using great pressure and heat. As a result, the diamonds are more likely to stay in place, even under the most demanding circumstances as they are effectively part of the substrate, not just stuck to it.
All this adds up to a diamond plate which shall continue to work long after a lesser plate has shed it's diamonds and can be used more 'vigorously' as the diamonds are more securely held in place. Simply put, these plates can handle the pressure, as much as you care to exert upon them.
Constructed as a diamond/steel/aluminium 'sandwich', the thick aluminium base plate offers incredible rigidity without adding unnecessary weight, while the steel offer a resilient base to which the diamonds are fixed.
This #12000 grit is intended for final honing of plane blades and for steel blades that are known to be difficult to sharpen to a very fine edge by 'normal' means such as sharpening stones or honing compounds.
