- Feb 16, 2010
Well, years ago I made electro-etchers based on Chris Crawford's update to Bob Warner's design. It worked, but was cumbersome to build. Still, I always thought that while the design was solid, it could be better. It needed to be portable, and it needed to be just a few volts higher than a standard 12v transformer provided. I also wanted to build one that didn't rely on the ancient transformer technology that was the basis for the Warner/Crawford design.
So, I started from scratch with these requirements in mind:
I built a circuit based off a common 555 timer and an H-bridge to create a 30v square wave from a 20v DC input. In this case, that's a Ryobi 20v battery, but I plan to make other battery platforms available. This makes it a compact unit that is very quick to setup and takes up very little room in storage.
OK, I know what the experts are thinking: How do you have 50hz DC current? You understand that DC doesn't operate like that, right? Well, true, but I have it designed so that it does turn on and off 50 times per second via an IRF540, giving a 50hz pulsed operation. I've always found pulsing it on/off gave a better etch than always on.
Still early in the development, need to optimize the PCB a bit, and tweak the case design some more, maybe add an activation light, but I'm happy with it so far.
- 15VDC etching ability (operating at 50hz pulse)
- 30VAC marking ability (get that sucker DARK)
- Battery operated
- Overall better performance than previous designs, while being smaller and lighter
