Hey everyone, first let me quickly do a little intro that may help answer a few of my questions.
Just recently got into knives rather seriously and right off the bat I want to be able to sharpen all my knives to a very high degree of sharpness. To be honest, time is not really an issue at all in terms of sharpening. I have been reading a LOT of amazingly useful posts here the last few weeks and I think I have gotten to the point where I have read enough to get me started with sharpening my knives via the EPA system.
Here is basically what I want to get out of this system and what I will use it for presently, and in the future.
I want to start off sharpening some crappy knives (Friend has like 200 junky knives, so I will have as many as I need to practice on), then progress to sharpening my own knives to a mirror polish and bevel changing, as precise as I possibly can with this system. After I get them to where I want (changing bevel angle + mirror polish), I will just be touching them up every other week or so. What stone progression should I use to really get the most out of this system for the "first" sharpen, and then what should I use to basically upkeep them? The first of my knives, which I carry every day and the one I will focus on first is an S30V Sage 1. So here is what I was thinking. Start with Atoma 140 for setting the bevel, then go 400, 800, 1000, 3000, 5000, 10000 all Chosera. Then HA strop for EP first using Chromium Oxide .5 micron, then finishing with HA Diamond Spray .25 micron. Am I missing anything? What changes should I make?
The next application will be further down the line, and will involve sharpening many more knives to generally the same sharpness. For this I just want to make the knives have an edge that can slice paper with ease but can hold up with general usage (as much as I can with just sharpening, not factoring in the steel), basically wondering the stone progression and bevel angle to get an edge for that use that I can do on most generic steels. Was thinking getting 40 degree via Atoma 140, then going 400, 600, 800 grit Chosera, then just ending with HA strop on EP + Chromium Oxide .5 micron. I still want to be able to make it look very polished, but want to keep it at 30 or 40 degrees (or whatever angle would be better for these applications).
In terms of the EPA system itself, I do have a few questions about that, which I hope can be answered, if not I can always call them or CKtG.
In terms of little trinkets that I think I need, I think the drill stop collar, angle cube, DMT XXC to flatten stones (Can I / should I flatten them all with this, or should I get a different DMT plate for certain Chosera's), and I kinda want that microscope that CKtG has on their site for $65, to examine edges.
What would you suggest to remove burrs?
On that note, does someone know somewhere that explains burrs for a beginner? I think I know what it is, so correct me if I am wrong.
When you sharpen one side of a knife, the edge basically rolls over a little at the top, so the trick is to find it when its the smallest, and that's when you know to switch to the other side of the blade then sharpen that side and feel for the burr on the other side, rinse repeat?
So my questions basically are: When do you know when to stop sharpening each side, and when do you know when to stop sharpening with a certain stone and move on to the next?
Last two questions for now:
I don't understand how you are able to keep the blade perfectly still when holding it on the "ramp" while you sharpen it, from all the videos I have watched, it seems to slide a little up and down when you are working the arm on the Apex because the spine is curved (usually) so it does not sit flush with the piece that is meant to keep it from sliding down.
When you are adjusting the piece on the ramp that keeps the blade from sliding down, how do you know how far to adjust it (I know you want the blade to overhang, but by how much? Because if its too much or too little, wont the angle change?
Really appreciate any help that anyone can provide as I am a novice so I want to absorb any and all advice and positive criticism that you guys have to offer.
