Cold Steel Pocket Bushman
"The blade is long and wide with a short sharp clip point for usefulness and versatility. And it’s hollow ground from top to bottom with just enough belly to be useful for all sorts of tasks. For the handle we used the mono block construction method famously used in the French Douk Douk line of knives.Specifications: Blade: 4 1/2" Handle: 5 3/4" Long. 420 Series Stainless w/ Bead Blast Finish Overall: 10 1/4" Thick: 3.5mm Weight: 6.1 oz. Steel: Krupp 4116 Stainless Blade"
The only drawback is that the lock is so strong, it is difficult to close. Oil it, work the blade and lock a bit when you first get it, and it's no problem. At that price, the edge will need touching up more than a more expensive steel, but it's a good working knife and can definitely take stress. Reasonably comfortable handle. $25
