- Dec 18, 2008
Hello Everyone - I want to say, if you do not have a grinder with variable speed, you need one. It is amazing. I can actually control things now.
I just set this up today, I got it yesterday. I call it SUPERGRINDER although it is really just Uncle Al's standard model. Plug and play like this.
$1,700.00 and change, delivered. Edited to add - 1.5 hp, 120, variable.
I am going to spend some time working in the shop over the next couple of days, finally. Stupid day job, don't they realize I have knives to make, things to grind...?
thanks for looking. I have never used a kmg, only Baders and Grizzlies. Please don't anyone launch into how wonderful kmg's are. I am certain that they are a high quality machine. I happened to want this machine, for many very good reasons, and it has surpassed my expectations.
Also - you will want to pay close attention to the tensioning mechanism. It is novel, and it works very well. It has a cylinder with an angle cut on top as the bottom structural piece. Then, a piston with a small cylinder and then a ring around it form the top half. The piston fits into the bottom cylinder, with the ring and then the smaller top cylinder around the piston. When you push up on the lever, the piston moves up and the top cylinder pushes the ring down against the bottom cylinder. Now, the neat part, when the tension pushes down on this contraption, the ring presses against the angle in the bottom cylinder, causing it to tilt. The tilted ring binds the piston so it can't move. THIS IS A SYSTEM THAT CAN MOVE UP BUT NOT DOWN UNLESS YOU FREE THE RING BY LIFTING THE LITTLE TAB. Clever, simple. Works great.
take care,
kc
take care,
kc
