Thanks for posting that Scurvy, much appreciated.
I saw this thread and was excited that there had been a new Skyline release...
Sorry about the confusion and thanks for posting everyone. So I've tried out both methods and the button press works slowly and only when the knife is towards the floor, and the switch flick doesn't work at all. I think the switch flick doesn't work out because my hands are too small. Advice?
Yes, exactly this. My Skyline was very difficult to flip open with just my finger initially. When I disassembled it, polished the washers and added a little lube it became a consistently easy flipper. Also since these are mass produced, it's expected that some may flip perfectly from the factory while others not quite. The good news is its a rather easy 'fix' if you're comfortable taking the knife apart.Take it apart, clean it well (grease, grit, etc), and then reassemble with a tiny bit of tuff glide or some other light lubricant. Experiment with the tightness of the pivot. You can run it slightly loose, especially if you use some of the weaker loctite on the screw. My skyline flies open at all angles.
You need to practice your technique, that is the only advice I can offer. Ypou need to press the flipper into the handle quickly and with authority. Not everyone can do that from the first time, which is why practice is important. If all else failte, use the thumbstud/bladestops.Sorry about the confusion and thanks for posting everyone. So I've tried out both methods and the button press works slowly and only when the knife is towards the floor, and the switch flick doesn't work at all. I think the switch flick doesn't work out because my hands are too small. Advice?
I notice my smaller Ripple is not as easy to flip as my larger one so that may be it.
