re: belt supplies
Check out
www.trugrit.com. They have good prices on abrasive belts, plus a good variety. If you bought a 1 x 42 sander you will have better luck finding belts than if you got a smaller one.
There is an incredible variety of belts out there. "Get the best you can afford" is good advice, but there are specific types that you should look for.
Manufacturers use different types of materials in the manufacture of abrasive belts. The most common, and cheapest, is aluminum oxide. Aluminum oxide belts work well on wood. The standard, cheap aluminum oxide will do OK on metal, but will wear out fast.
There is another type of aluminum oxide belt. These belts look quite a bit different than the normal belt. These are called "structured abrasive" belt, and the grit is arranged in little raised boxes. It's difficult to describe, just look at a picture and you will see what I mean. The brands of structured abrasive belts are the Norton Norax, 3M Trizact, and 3M Trizact CF (also called "Gator"). The Norton Norax and 3M Gator belts are excellent. They cut fast and don't produce much heat buildup. They also seem to last pretty long.
Another abrasive is silicon carbide. This is the same abrasive that is in wetordry sandpaper. These belts are waterproof. I have no experience with them.
Alumina Zirconia is an abrasive used on metal, which lasts longer than standard aluminum oxide. I don't know how it holds up to structured abrasive belts. I don't use this type of belt.
Ceramic is the most long lasting and wear resistant abrasive. Both Norton and 3M make ceramic belts. I like the 3M Super Cubitron ceramic belts (they are gold colored), but some like the Norton "Hogger" Ceramic belts better. These ceramic belts can remove a lot of material very quickly and last a long time.
They are usually only available in lower grits. If you have to reprofile a khuk, go for an 80 grit ceramic belt. Then finish up with a higher grit Norax or Gator belt, probably up to 400 grit or so. You may want to take an intermediate step, so you could go from 80 to 220 to 400, or something like that.
For general sharpening, 400 and 800 grit Norax belts work well for me. You can also buy super high grit Norax or Trizact belts. My friend has a 2000 grit Trizact belt, and likes it.
Now, if you go to TruGrit most of these more exotic belts are only available in the 2 x 72 size. It looks like they have an 80 grit Norton ceramic and a 240 grit Gator belt in the 1 x 42 size. I would recommend you buy these two belts. You could also get one of the finer grit aluminum oxide belts, or finish up with hand sanding. More belts may be available for your size grinder from other online stores, so shop around a bit.
