Does it prevent the pen from fully closing or the sheepsfoot from opening without opening the pen blade first?
If not, I wouldn't worry about it.
Generally speaking, two spring stockman are known for a little blade rub. It comes with the pattern.
You can thin the offending pen blade's tip a little on your fine sharpening stone, to eliminate or reduce the rub, depending on how bad it is, or bend the sheepsfoot very slightly towards the clip point, if there is room. (lay sheepsfoot flat on table, hold sheepsfoot with off hand flat on table, push or pull on handle to bend the blade the proper direction.)
Good looking knife. You should get many years use from her.
(note: I'm presuming the pen blade is just shy of rubbing the liner, so you can't bend that blade away from the sheepsfoot.)
