- Jul 22, 2013
New knife maker here. Starting out doing some stock removal to get my skills down. Then I hope to move into forging my own blades.
Since I’m new, I’m not very good at grinding. Since I have no experience at all, I got 2 different types of jigs and for a reference I free handed. I got Fred’s bubble jig, a Creativeman beveling jig/file guide, and then obviously free hand grinding. I went to Home Depot and got some mild steel and cut out a few knife blanks. To keep the results consistent I made the same style knife for all three.
The first two pictures are using the bubble jig. I started out with the 10° wedge to knock my edges off and set the bevel profile. Then I moved to the 5° block. That is where I stopped for that particular jig. I got really good results on one side, and some not so good results on the other side.
The second set of pictures are using the Creativeman file guide and jig. I started out at a very sharp angle to knock the edges off and then progressively lowered the angle until my bevels where I wanted them. With this particular set up, I did find that I grind it over my center line very easily.
The last set of pictures are my attempt at free handing. I was very happy with the one side of the blade. Obviously pulling with my right hand is my strong side. Ignore the grind marks up near the top, I flattened the steel on my Platten and that’s where some of the grind marks near the spine of the blade are coming from.
All in all, I got good results on one side doing freehand and the bubble jig. The Creativeman file guide and jig gave me semi-consistent results from side to side, there was just a little problem of grinding over my center line. This is obviously user error. I think I stayed at the same angle for too many passes as opposed to decreasing my angle when I should have.
Take away message, I definitely need to work on my left hand pull side with the bubble and and free handing. And I need to work on reducing my angles at the proper time while using the Creativeman file guide and jig together.
What belt speed are you guys running when grinding primary bevels. I am using a 36grit ceramic belt. I have heard that most people are at 3-5K fpm?
