Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
Getting a new knife is usually a happy experience, the hunt as we know is a greater part of the pleasure of getting, but when it arrives it may not live up to the expectations you held. Usually the edge is 'sharp' but you expected something more, something along the lines of vorpal quality. Now some knives arrive brightly sharp as there are a few companies that provide a sharp edge right out of the box, but even those can benefit from getting their bevels leveled out and that brings a nicer experience when cutting.
Recently I've a couple higher priced knives that I was surprised to see that the edge bevel wavered a little bit which meant that I will have to spend some times on the stones to get them evened out. I hate sharpening something right from the get go as that just removes metal/life of the blade, albeit slightly but still there is some loss. And some take a good deal of time to right things.
Here's a rough drawing of what I'm trying to say, the grey areas are where the edge bevel dips/wavers and is not in a single plane. For me, I angle the blade up towards a ceiling light and sight down along the bevel to see if it is all in the same plane and that each side is about the same width.
edgebevel by GaryWGraley, on Flickr
Getting that flattened down so it is in a single plane takes time and patience. But I believe that it results in a much better cutting experience.
Now some of you guys and gals might not be up to getting things back to a flat bevel (or convex for those types of edges) and I would recommend that if you really like the knife a lot, take the expense of getting one of the folks on the forum that deals in sharpening to set those bevels for you. You'll be a lot happier for sure and maintaining that edge will be something that should be easier for you to do, by stropping or stoning as once the bevels are set you have a good starting point.
I put this in General as most in General are people that get new knives all the time but may feel buyers remorse if the knife doesn't perform like they envisioned. One other thing that helps a great deal is the edge bevel angles, some knives arrive with a very very narrow bevel grind that while might shave hair, doesn't cut into material as efficiently as a better more acute bevel would do and that's where you will see benefits from having your knife sharpened up.
Start the new year with a fresh edge bevel, it'll certainly help
G2
Edited to recommend one person that I've had personal experience and Bryce's sharpening is really very nice
Petunia D. Feeble
edgebevel by GaryWGraley, on FlickrGetting that flattened down so it is in a single plane takes time and patience. But I believe that it results in a much better cutting experience.
G2
