New Laser Strike wilderness knife
  • Thread starter Thread starter -
  • Start date Start date
This is the new Laser Strike wilderness knife that we introduced at SOF this past week. Sorry for the bad photo but it's the best we have at the moment.
Production is scheduled to begin in 3-4 weeks. The production pieces will be laser etched with the knife name, serial number, and have our logo burned into the handle.
The design allows the user 3 choices for making fire: ferrocium rod, true flint striker on the back portion of the handle, and bow drill divot. Overall length is 10 inches with a 4 1/2" cutting edge, full flat ground from 3/16" 1095 steel, micarta slabs, kydex sheath. Manufacturer is TOPS.
Will be taking orders in about 4 weeks.
Jeff
Randall's Adventure & Training
jeff@jungletraining.com
Jeff, any idea where I can buy the plain ferrocium rods? Not in the form of the Strike Force or Blast Match but just the rods in say 3' lengths or whatever is available?
Ron,
Bremerton, Washington
[This message has been edited by muzzleup (edited 10-17-2000).]
Hi Muzzleup,
Look at Jeff's own site he sells them for $12 + $1 postage if I'm correct.
These Light-my-Fire Large Military Firesteels that he also uses in his Laserstrike knife combo are good, very good.
Best Scouting wishes from Holland,
Bagheera
How well does the drill divot in the micarta pivot? Off hand micarta would seem to offer a decent amount of friction.
Stryver
HM, price is going to be 179.95 including the ferrocium striker rod.
Stryver, we've done extensive testing using Micarta as a drill holder and never failed to produce a coal on the fireboard. The Micarta actually slickens up after the first time using it. Just point your drill off with the knife on both ends, jab out a small hole in your fireboard next to your coal relief and have at it. As an added bonus, the large bow drill divot makes for good thumb position when used in a choke back mode for light chopping.
Added info:
We have also started numerous fires with true flint and steel (not ferrocium) using brown flint and charred cotton batting. The back strap throws good sparks on sharp flint and when the flint gets dull simply break it again by hitting it with the spine of the knife. Strike the flint with the knife tip pointed down and your thumb in the bow drill divot. The char cloth should be on top of the flint and the flint edge angled to throw sparks into the char when struck downward.
From the factory the back strap has been sanded smooth and left un-coated, a few hard strikes against flint roughens it up a bit and sparks get better the more you use it....and for those thinking the roughened back strap will hurt your hand...well you just need to see Fullers fine contouring work to appreciate it. You can hardly feel the raised back strap.
The enclosed ferrocium rod is attached with a safety ring and lanyard through the sheath and held in place with Ranger bands. No need to remove the rod's lanyard from the sheath to use the rod. The rod can be stroked with the edge of the knife's spine or the edge of the blade at the handle end. Until the ferrocium wears a bit, the cutting edge of the knife produces better showers of sparks...who cares that you're dulling the back 1/2" of the edge...do you ever use that part anyway?
The knife comes literally shaving sharp as expected from TOPs...and can be brought back to hair popping sharp with a few strokes on a Spyderco 204, pocket ceramic, or smooth field stones.
There's nothing fancy about this piece, it's designed as a working knife with an emphasis on fire-making and wilderness chores. Several writers have contacted us about reviewing the knife for various publications. As it stands now the first magazine that will get to do any reviews is Tactical Knives. I have informed editor Steve Dick to have whoever writes it up to write it as they see it. I love critical reviews.
The first 6 finished pieces are at the engravers for logos, name, and serial numbers. These will be run in lots of 50 pieces at a time with the first 50 due in about 2 months. We're not planning on running any larger quantities at this time and really cant give definite schedule dates. They will be available on first come - first served basis so don't bitch if they're not in stock.
Bottom line is we're not interested in making a living selling knives, we are interested in producing products and gear that works in the field, so anyone that wants to buy one and keep it in pristine condition without scratching it up should spend their money on a collector piece somewhere. All we ask is if you buy it then be sure to put it to work in the field.
Forget about any lifetime unlimited warranty. If there is failure due to material or workmanship we will replace it. If you use it as a damn prybar and break it...it's yours....so anyone interested in destructive testing or chopping materials like steel rebar ahould find another knife to buy. So what we're saying is if you don't like our attitude then don't buy it
and those who may review this blade in the future can quote me on that
Regards,
Jeff
Hi Jeff,
You wrote:
"The enclosed ferrocium rod is attached with a safety ring and lanyard through the sheath and held in place with Ranger bands. No need to remove the rod's lanyard from the sheath to use the rod."
I'm wondering why haven't you opted for a "fixed" place for the Ferrocium rod in the sheath, so molded to hold the Military Fireteel securely by the molded on thumb tab?
Is it because this would limit a good fit to only the Large Military Firesteel from Light-My-Fire from Sweden? and by using elastic bands you can attach any ferrocium rod to the sheath?
Also how do you keep the lanyard attached to the sheath and the ferrocium rod from getting entangled when you wlk through the bush? I try to envision how long it should be because you write that you don't need to losen the lanyard when you want to use the rod so when sitting on your knees it must be at least 1 to 2 feet long.
If the firesteel had a fixed place in the sheath it would not need a lanyard at all, correct me if I'm wrong.
Bagheera
Hi Jeff,
Sorry I missed that post.
Your correct that the KISS principle is the way to go.
Cheers,
Bagheera
