- Jul 12, 2002
Just added a new SAK and light for EDC carry. The light works very well for it's size. Easily out shining the AA minimag. I havn't had the opportunity to use the SAK yet, but if it's anything like the rest I've owned and used, it should do an excellent job for me.
The knife is based on the Victorinox Trekker so they share the same tools. This is the German issue field knife and comes with the OD scales and the German eagle set into the handle.
Large locking, one hand open, partially serrated blade
Can opener with small screwdriver
Bottle opener with large locking screwdriver & wire stripper
Wood saw
Sturdy reamer
Phillips screwdriver
Key ring
The new flashlight is the Dorcy Super 1 Watt with Luxeon bulb.
Case Material ........................... Anodized aluminum
Case Features .......................... Ribbed for grip
Case Access Type .................... Unscrew tailcap
Switch Type ............................. Tailcap Clickie - reverse type
Reflector Type ......................... Smooth, silvered
Lens Type ................................ Clear plastic
Bulb Type ................................. Luxeon I LED
Beam Type ............................... Spot
Beam Characteristics ............... Smooth, clean
Battery / Power Type................ 1 x 123A cell
Environmental Protection ......... O-rings, rubber seals
Weight (oz.) with batteries ....... 2.8
Wood saw
Sturdy reamer
Key ring
