Stickbait said:...;was this the A2 blade you had post about earlier with information about the supplier for the various types of steel blanks one can buy?Also I'm interested in how you attached the brass guard to the blade.Low-temperature solder?Pinned?Thanks and good job.![]()
Cliff Stamp said:Nice job, did you have a scope work in mind for the knife when you made it, or was it just an attempt to duplicate a known profile?
-Cliff
Scope of work is a term which generally means, for which tasks is this knife designed to perform. The low sabre grind generally makes a good prybar class knife, but you often see it on knives which are obviously not meant for such use.nozh2002 said:What is scope work?
Cliff Stamp said:Scope of work is a term which generally means, for which tasks is this knife designed to perform. The low sabre grind generally makes a good prybar class knife, but you often see it on knives which are obviously not meant for such use.
-Cliff
