- Jun 14, 2014
So I finally got my shop put together enough I can make swords.
My first sword was originally intended to be a XIIIb but I had trouble keeping everything even and lined up and the only way to save it was to grind the profil into a type XIV. I feel it works ok I just ended up with a light duty thin XIV due to the distal taper.
I want to talk about my heat treat process, the results I got, and what I can do better.
First my rig:
My ovens are horizontal made of stacked soft fire brick on top of ceramic fiber duraboard by Fiberfrax with a line of hard firebrick down the center to support the sword. Heated by two 24" half round ceramic fiber heaters (back to back for 48" of heat centered over a 52" chamber) made by Watlow and rated for continuous operation up to 2200 degrees F. The heaters are covered by half round ceramic fiber board and blankets on top for the high temp oven. The low temp tempering oven is the same thing but no blankets. My ovens and quench tube are controlled by Watlow 93 microprocessor controllers with K type thermocouples. When I put a cold blade (20 degree ambiant temp in shop) the oven loses about 80 degrees and takes about ten minutes to ramp back up. My controllers are set up to bring it up slow and soft. Once it gets to temp I start the timer for soak. All temperatures I talk about in my process where hit and held + or - 10 degrees F.
The idea was to get a bainite structure with as much martensite as I could manage for the edges and thin areas
steel is 1095
I normalized:
Heated to 1575 with a ten minute soak cooled to black in still air
Heated to 1525 with ten minute soak and cooled in air
Heated to 1475 with ten minute soak and cooled in still air
Austenitized at 1475 with a ten minute soak
Quenched into McMaster Carr fast quench oil heated to 320 degrees and held in quench for five seconds with some slight agitation (oil temp rose to about 380)
I moved the sword from oil to tempering oven in about two to three seconds to prevent air cooling
Tempering oven was preheated to 550 degrees sword was held there for just over three hours
I don't have access to salt pots so I'm hoping heat is heat and there's no magic in salt other than rapid transfer of heat through contact and that bainite will have formed in the tempering oven where I did not get martensite.
One concern I had right away was that my tempering oven rose to about 565 degrees when I put the quenched blade in making me think I should have held it in quench longer
So after I cleaned it up a little just to knock the little bit of scale off I took it to work to put in the hardness tester
The thin parts below the fuller ranged from 52 to 57 HRC
The thicker parts around the fuller and tang ranged from 46 to 49 HRC with the softest part in the center of the tang just behind the fuller and that one actually hit 44
The sword can be flexed just over ninety degrees and will return to true
So those of you with more experience how did I do, what have I likely got and what can I do better?
Thank you
First my rig:
steel is 1095
I normalized:
Thank you
