New Taiwanese Spyderench Observations
Greetings:
I just recently took delivery of one of the new Spyderenches. I chose it over the Byrdrench for several reasons:
  • Origin of manufacture (I wish to studiously avoid reopening this well-discussed thread!)
  • The better utility (for me) of the combo edge
  • My familiarity with AUS-8 steel versus the steel Byrd knives use
  • My preference of the diamond file
While the fit and finish are excellent and they are now including a small plastic insert to keep all of the loose bits in place (I don't recall this in the original "rench"), there are several notable differences between this tool and the original USA-produced Spyderench that potential buyers should be aware of.
  1. One end of the diamond file now contains a rounded punch instead of the previous model's flat-head screwdriver. This punch is neither sharp nor does it have angular shoulders like a drift. The only purpose it clearly serves is as a good ball-detent to keep the "rench" together in my pocket.
  2. The file no longer fits in the hex-shaped bit holder. As a result, you cannot use the tool as a handle for the philips end of the file. This was one of the more charming features of the original Spyderench. Sad to see it go. The instructions (unlike the older model) make no reference to using the screwdriver end of the file this way.
From my perspective both of these are a step backwards (YMMV). Just thought I would point them out for the benefit of others who may be considering a purchase or alternately considering between the Spyderench and the Byrdrench.
-Best,
/Andy
I was also disappointed that the driver/file no longer fits in the hex adapter. :(
Also, my SpydeRench (2007) had some problems with blade wobble (see photo):
http://www.bladeforums.com/forums/showthread.php?t=491631
I received a replacement from Spyderco and it's better but there's still a little bit of play--it doesn't hit the "liner" though. I'm wondering if this is a common problem or an isolated incedent. Does your SpydeRench have the same problem?
There is a very slight amount of blade wobble but not enough to hit the liner. The locking spring is quite stiff, however, and the bearing surface of the blade at the pivot wasn't polished as nicely as other Spyderco knives. This makes for one-handed opening that is a bit slow and rough. Given that it is a multitool I regard these as nits. I find the Delica-style blade to suit my needs much better than virtually any blade on a multi-tool.
Thanks for the response! The replacement that I received from Spyderco seems to be on par with your SpydeRench. Maybe the first one was a fluke.
