ARtsig1
Banned
- Jul 20, 2000
........would be the newest framelock by none other than J.W. Smith! The model designation is FL-1, and so far is #1 in my book. First thing you notice when you pick it up is the weight of it as it is on the hefty side. Next is the way the cf overlays fit the palm of your hand and give the knife a feeling as if it were an extension of your arm.
Opening the knife is a pleasure all its on. With one push of the thumb you see the blade glide open, and if done right, just seems to fall into the locked position. The lockup is accompanied by a nice deep KER-THUNK that lets you KNOW the lock is engaged. Closing the knife requires a strong push on the frame lock as the way John cuts it and bends it it is quite strong. As a matter of fact it is the strongest spring I've ever felt in a framelock. As the blade comes to the closed position the frame lock ball detent snaps over and holds the blade in place with no doubt in your mind that the blade is going anywhere without you wanting it too. Lockup is tight in all directions as there is not a wiggle or a wobble and I TRIED to get a wiggle or a wobble out of it, believe me I TRIED!
As I said the knife is a hefty one and these specs will show that;
BLADE THICKNESS: .164"
BLADE LENGTH: 4.0"
HANDLE THICKNESS: .685" at the thickest point.
HANDLE LENGTH: 5.25"
OVERALL LENGTH: 9.25"
TITANIUM HANDLE PLATES: .130"
WEIGHT: 6.6 ounces
Well there you have it, the latest from down on Cow Branch Road in West Liberty, Kain-tucky! Btw I think it is John's finest framelock so far!!
How 'bout a pic...........This one came from Boink, and actually shows a 3.5" bladed FL-1.
BLADE LENGTH: 4.0"
WEIGHT: 6.6 ounces
