New to knife making and lots of questions
Hi everyone,
Last fall I got a wild hair that i wanted to learn blacksmithing and knife making so i went about building a propane forge out of an old air compressor and turned an old press into a forge press as my goal was to make damascus. Anyway, I've made 7 knives now and the last one was my very first damascus blade. I started out with 2 large knives made from horse rasps and 3 smaller ones made from metal files and one from a railroad spike. In any event here is where the questions start. The only blade that didn't warp during the quench was the railroad spike. All of the other blades have warped. The first 3 aside from the spike i was able to tweak right out of the oil with good results but that's where the wheels fell off of the operation. I made a small hunter out of a file and out of the quench there was a warp towards the tip. When i went to straighten it the tip broke off. I did regrind that blade and salvage it but the next one wasnt so lucky. It was a decent sized hunter made from a large metal file. Out if the quench it had a warp at about the middle of the blade. When i tried straightening it it snapped in the middle. I had about the same luck with my damascus blade except i was doing a hidden tang and the tang broke off. Since that was a damascus blade that i had a lot of time into i tig welded the tang back on and ground the tang further up the blade to hide the weld completely and finished the knife out. Now i have looked into my warping problem and have heard about 3 different theories. The first group say pull it out of the oil still hot, straighten, and go back in the oil. I obviously have had mixed results with this so ill move to the next method. The next group say run the blade through a tempering cycle then c-clamp it to a straight bar with some shims at the apex of the warp and run it through another tempering cycle. And the final group say just prevent it by stress relieving the blade multiple times and also stress relieve it after your initial grinding. Prevention sounds great but i hate to do my initial grinding and scale up the blade again. Ive read about several coating you can apply and also the foil to prevent scale but one guy will claim a certain coating works and the next will claim its crap. What do you guys recommend for my warpage problem and also for preventing scale? My final issue is a question for the damascus guys out there. This was my first billet so i was very concerned about getting good forge welds. Due to that fear i used the cut and stack method to increase layer count rather than the folding method. My only problem was every time i forged the bar out long and thin i would grind the surfaces smooth to get the best possible forge weld and by the time i hit 156 layers i was only working with probably 60% of the steel i started with. Do any of you use the fold method and if you do do you have trouble with inclusions and delaminations? Sorry for writing a book on my first post but any help you guys can offer would be greatly appreciated thank you.
Also, how do i post pictures to these threads? When i click the photo link on here it wants a url and i dont have any of these pictures on a website.
To post photos you need to sign up with a third party image hosting service, like imgur or photobucket. As far as fixing warps there are a ton of factors that might be a problem.
1st: If you are forging files you may be creating cold shuts along every groove, especially if you are using one of those big horse rasps. Every little sharp angle is a spot that may create a crack when you quench. Especially if you are not grinding until after heat treat. You may not find those cracks until you are trying to bend it to fix a warp. Start with 1084 high carbon it's not that expensive.
2nd: Is your blade straight? It has to be straight. Totally. Get as many hammer marks out as you can. Learn to planish well.
3rd: Normalize. Normalize. Normalize. Do it three times, always. That will help relieve the internal stresses
3rd: You might be over heating the blade. What are you quenching in? A more aggressive cool down will cause warping. Worst case would be over-heating the blade and quenching in water. Your case may be less severe, but may still cause issues. Pre-heat your oil, and dont over heat the blade.
4th: This may be controversial. When I go to quench I only heat the blade to the critical temperature, I never let the spine go red. It seems like this has helped to keep the warping of my blades to a minimum. It also can result in a hamon which is like an added bonus. Not sure how others feel about this method, but so far it has worked for me pretty well.
When I've been forging these blades I forge them out, straighten them, then bring them up to temperature and shut the forge down and let them cool off with the forge. Then i grind them to 70-80% complete and usually a 220 finish, then heat them just past non-magnetic, and quench in parks 50 oil that ive preheated by quenching a plow spike in it.
Here are most of the knives I've done.
Sorry about the first post. I had a lot to get out and should have broke it up into several smaller posts instead of writing a book.
The way I was taught to normalize for these kinds of steels, (1070, 1084, 1095, files and whatnot) was to heat as evenly as possible past the critical temp, and then let air cool 3 times in a row. Normalize before your quench. This is the stress relieving you are talking about. I'm not saying it will fix the warping issue, but it will help.
Thank you, I'm definitely going to try that along with an anti-scale compound.
To normalize you need to go hotter. if you want to even the grain, you first need to increase the grain size, so you need to get above 1600f for that to happen. Once the grain size is even, you refine grain through thermal cycling, going past critical, but not hot enough to grow grain size. New grains form within the existing grain boundaries. Typically, it's 1600/1650f depending on the steel, 1500/1550f, then 1400/1450f, air cooling to black (magnetic) between each cycle. If you are going to grind, drill, machine, 2h at 1200f will give you a fine spheroid anneal, which machines like butter.
Note:all of the above are for relatively simple carbon steels. High alloy steels, and air hardening steels are different.
Correct me if I'm wrong....but how do you know what temps to normalize or heat treat at if you are unsure of what specific kinds of steel your dealing with? Files, Spikes, Saw Blades are typically unknown stuff, right? Do I need to lurk for a few more weeks before I make these kinds of observations? :D
