New to knife making ?
There is a knifemaking section you might want to check out, probably get better answers
You can temper it, sure. As for heat treating (as in hardening), you might need more heat. Also, 1095 probably has a soak time which means you need to hold it at a higher temperature for a few minutes to get all of the carbon into solution. I’d recommend a coal forge at least, and preferably a heat treating oven. It is a lot easier to control the temperature.
I’ve not tried using a torch for a heat treatment before, but I’m sure it’s possible depending on the torch.
